francoisdotnet
- Joined
- Mar 30, 2011
- Messages
- 6
Hope you flashoholics can help me!?
I currently have a Fenix LD20 (R5) but think I can do better? And I would also prefer a single AA flashlight. I am looking for a flashlight that will be used in conjunction with my headlamp when the situation calls for it, typically when I need more brightness and throw. Also as a backup if the headlamp where to fail. As indicated below a strobe/beacon and SOS function is also required - which rules out a lot of flashlights.
One flashlight that stood out to me was one from DealExtreme but I don't know if there is better ones out there I haven't been able to find?
Flashlight Recommendation Checklist
X___I will be mail-ordering or buying online, so this doesn't matter. (Preferably that ships internationally)
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
X___I’m flexible, tell me what you gotJ. (Preferably, but not limited too < )
3) Format:
X___I want a Flashlight.
4) Flashlight-specific format/size:
X___Keychain size.
X___Every day carry small (2-4 inches).
X___Every day carry medium (4-7 inches).
[Any of the above]
5) Emitter/Light source:
X___LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
X___I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
7) What battery type do you want to use?
X___I would like to use (Lithium) AA (Preferably also allowing 14500)
[(Lithium) AAA is also welcome]
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
X___I want to illuminate my entire backyard or a campsite (150-300+ lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
X___120+ yards (I want maximum throw possible)
[With some flood would be a bonus]
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
X___50-90 minutes (I have plenty of batteries just ready to be changed; Runtime is moderately important, but still not critical)
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
X___Critical (Police, Fire, Search & Rescue, Caving, Survival).
12) Switch Type and location (choose all that apply):
X___I prefer a forward clicky (Helpful for momentary activation and signaling).
X___I don't mind a reverse clicky (For use with multi-mode/level lights).
X___I don't mind twisty switch preferably in combination with a tail switch (Tighten the head/tailcap to activate, and the light will stay on until the head/tailcap is loosened).
X___I prefer a tail mounted switch (found on the majority of today’s high end lights).
____A simple on-off with only one output level is fine for me.
X___I want 2 (or more) light levels. (Brighter/short runtime and Dimmer/long runtime.)
____I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
____I want a strobe mode. (Blinks to show location.)
X___I want SOS mode.
X___I want a beacon mode. (thought this is "Blinks to show location"?)
14)Material/Finish/Coating
X___Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today’s flashlights).
X___OR, Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
X___Pocket/belt clip
X___Wrist/Neck Lanyard
Thanks in advance for your suggestions!
3) Format:
X___Keychain size.
[Any of the above]
6) Manufacturer:
