Need allrounder
zakazak
____I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
____Less than $100.
____I'm flexible, tell me what you gotJ.
3) Format:
____I want a flashlight.
4) Flashlight-specific format/size:
____Every day carry medium (4-7 inches).
5) Emitter/Light source:
____LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
____I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
____I would consider getting a light that is pieced together (for example a "host" or flashlight body from one manufacturer, and a "drop-in" emitter from another source). Under the right circumstances, this path can provide more options to the consumer to meet specific needs, and can often be easily upgradeable as technology improves.
7) What battery type do you want to use?
No idea tbh
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
I like to change it like on the Led Lenser M7/P7/T7
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
For everything. It is for working, hiking , etc.. it will be my allrounder for everything.
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
The longer the better
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
Would be nice if it is IPX 8 (waterproof)
12) Switch Type and location (choose all that apply):
____I don't know.
I had the Led Lenser P7 and it was nice :)
____I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
14)Material/Finish/Coating
____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's flashlights).
____Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
____I don't care.
Needs to be durable !
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
Would be nice if you could put the flashlight down and work without having it rolling around/coasting).
Hmm? The first post includes the 15 Questions & Answers from the sticky?
One of my favorite lights now is the Olight M20x. It takes two cr1onerous one 18650 battery. I recommend the latter as it will provide more run time and they are rechargable. The light gets 500 lumens and is a very tough light (see m20 torture test on YouTube) has a great low, low, medium and high setting. It has a powerful strobe in case you need to get attention and is one handed operation. No twisting of led heads or hidden modes, etc. it is also light weight and comes with a great holster that you can put on the outside of your pack. The mix of throw and flood is very good. For $100 you can get the light and two batteries and a charger. Highly recommend that you call Marshal at link removed as they carry everything. Btw, I carry this light in my go bag.
@varmint: All the needed answers are there :o
@EnduringEagle: Wow it looks really great.. but if I got it right then there is no way to actually change the light focus? You can only make weaker/stronger but can't change to wide focus / small focus (for long distance) ?
Thanks
A flashlight with focusing mechanism is nowhere near durable or waterproof as a fixed-focused light.
Get a light with balanced throw and flood. EagleTac T20C2 MkII or Quark Tactical will be great. If you need them in AA flavor, P20A2 MkII and Quark Tactical AA are available as well.
Ah I guess you are right.. then I propably will go for the Olight M20x.. so far it looks like the best recommendation.
Eagletac G25c2 looks like it would fit your criteria.
So would a Sunwayman V10r or V20A
I EDC a Zebralight Sc600, doesn't have a selector ring but you can program in 3 levels of 6 and an nice shortcut to start on low or high. .1 lumens or 750 lumens otf
zakazak; Did I spell that right?
Basically, flashlights are tools! They are marvelous pieces of technology, and it amazes me what has happened in the last 5 years! WOWZA! Despite the hype and advertising "differences" that tout Levels, Modes, (mostly of little use, IMNHO) Cool white, warm white, white white, etc.,etc. tints and other things, flashlights do only one thing best...provide Forum members with much fuel for discussion! And that is good! Some of the people on here could be, and probably are, rocket scientists.
Don't get dazzled.(pun intended) Start easy and inexpen$ive. You're new, right ? I have: 2 3D mags, modded, one with a hotwire Luxeon III, and I promised myself NEVER again! The other has a Diamond 3 Watt insert. Great all-round lights, nearly equal, but, I am a bit tired of hauling the weight and bulk around. And now, they are a bit much for a living room light. I am tossing the coin between the Maglite ML100 (LED) 2 or 3 C cell, or the Streamlight Twin Task all-LED C cell model. They are lighter, have 2 brightnesses, and will not break the bank. Old technology? Well, so is the Browning M2 .50 caliber machine gun...but it still works...O MY yes!
My dream light was and still is, the Surefire E2L AA Outdoorsman, but I had been completely happy with my MiniMaglites with Terralux or Nite-Ize LED Modules...still extremely capable lights, and small! That is, until I got my New MiniMagLED. WOW! Bright, with a low setting that nearly matches the best of my MiniMag mods. Next, I got the Terralux Lightstar 220...again WOW! Almost too bright for the backyard, but, low does great. Of course, the two of them have those annoying extra modes...strobe and SOS. I avoid them whenever possible, allthough they would seem to be handy if you had to call in an air strike on the wild animal that ran away with your shoes and other flashlights. In truth, in a real emergency situation, I suppose a strobing light would be easier to observe.
For that matter, go somewhere that sells true industrial flashlights, and pick up one of their 2 D or 3 D models, then drop in a PR based LED. For not much money, you will have a very capable light I have a military angle-head 2 D flashlight, and a probably 3.99 2D that the wife found somewhere, and I dropped in a couple of the no-name PR based LEDs I have had since about, 2005 when I joined the forum. Not as bright as the incandescent bulbs, but much longer run time...a better light, IMO, although the incandescent bulbs are perfectly adequate. We just don't LIKE the yellowish, artifact-ridden beam! Picky, ain't we?
So, start easy, and as you figure out what you would like, as opposed to what everybody says you will like (and, probably would) because they have one, (or, on here, more likely, one of each!) then buy as many of what ever you like as you want. There are people out there that will sell you that many.
Good luck, and don't be a stranger.
The good news is that all the lights that have been recommended are all very good. Is there a perfect light out there? Personally I have not found it yet but it is all a matter of criteria.
