Need help finding a driver
LeMieux
Hello! i need help choosing a driver to run some Cree XML-T6 emitters with. Preferably single mode (full power) but 2-3 mode would be acceptabel. Input voltage would have to be 5-15volts (those are ballpark numbers. May be runnign off of a few different sources) Im looking for quality, but dont want to spend much more than 15-20$ per driver. Any help is much appreciated!
Here's a good list for you to look over. Alot of the drivers have been tested here on cpf if you search. Search using the sku number it gives you in the descripition. CPF contains alot of info on some of the drivers in that list. Alot of the drivers have been modified by members to run higher voltages or higher currents. The 57779 from dealextreme is probably the one i would use. Info on modding it to a one mode driver here and here. If you want high quality look at Taskled drivers.
