Did you check my info in post 8 ?
That caused lack of video for me once.
The enable java is checked. Should I uncheck block pop-up window? Would that allow unwanted popup when surfing the web?
If you have the proper flash plugin, don't forget to allow 'ytimg' if you are running 'No Script'.
Make sure in FF menu , you are accepting cookies ... also 3rd party cookies.
Some things wont work if they cant set their cookies.
Blocking pop-ups does not prevent my videos from showing.
You could try it to be sure.
It set on accept cookies, but I also set it to "keep until I close firefox." Do you think that is the problem?
