[ QUOTE ]
louie said:
You may have a defective battery or camera. I've used NiMH and Radio Shack, Rayovac and now Maha C401FS chargers. I've tried Nexcell, RadioShack, Rayovac and Powerex NiMH AAs, and anecdotally, through 3 digicams, the Maha and Powerex 2000mAh are excellent. Part of this may be better power management on the camera's part (Canon A70), but recharging every 5 days sounds like a defect somewhere. I have almost given up on obsessively carrying around extra AAs for a day's shooting now.
I've run into bad AA cells, and it's tough to find them. One clue is to run them hard until the camera conks out, then immediately check the voltage of each cell. I think bad cells will have a significantly lower voltage, at least for several seconds.
[/ QUOTE ]
Almost all digital cameras adore Nimh batteries. They like the stiff power. Alks rarely work well. I'd go with the charger being bad, or a battery failure. A quick and good way to test for the bad cell(s) that I've used in the past is to run 'til failure, then pop 'em out and hook each one to a 1 or 2 cell PR bulb, preferably a hi-current one. (2.4V at .5A for example.) This loads 'em decent, and hold it for a bit, watching for fadeout. Test a known good one fresh from charge, so you know what it should look like. If you have a shot cell, this'll almost definitely show it.
I don't know the camera model specs, but it's a possibility that if your batteries are good, that it's ill or not designed for the lower voltage from rechargable batts. Almost all are designed for them, tho..
Good luck!!
I hated my digicams 'til I tried a good set of Nimh in them. Then, it's flash 'til the cards fill up!
Yours, drs the crazed..
