Well, the STL-V6 is not about the batteries (2 of them) but rather by design of its driver. If it were a 1-cell 18650 regulated driver at 2.8-3A it would only stay in regulation for a very short while - not very useful. Even with the best NCR18650A 3100mAh it would be like 15-20 mins?
I think there is one candidate which you'd be interested in, Sky Ray STL-V3. It is a wee bit bigger than the Keygos, but that bit of difference makes all the difference. Remember stepping up from 40mm class reflector to 59mm of the STL-V6, the lux jumps a lot. Theorectically you get 4X the lux with 2X the diameter. But then in throw, you need 4X lux to get 2X distance. But of course inverse square law does not always work in reality, but it is still "around there" and a pretty good gauge for us. :).
Unfortunately the STL-V3 is way too expensive. I suspect it is current regulated as well....
