Need New 2AA or 3AA light
himself
Need a 2AA 3AA or 18650 integrated rechargeable light. Key feature is completely exposed tactical forward clicky tail switch. No recessed switches, or partially recessed. The whole thing needs to be exposed. Similar to the Sunwayman T20CS. If they had a rechargeable light in this form I would be sold!
____I will be mail-ordering or buying online.
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
____Less than $100.
3) Format:
____I want a flashlight.
4) Flashlight-specific format/size:
____Every day carry medium (4-7 inches).
5) Emitter/Light source:
____LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
____I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
7) What battery type do you want to use?
____I intend to use AA batteries
____Option - I want a light with an integrated rechargeable battery. (Note: these choices may be very limited unless you are looking at spotlights)
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
____I want to illuminate my entire backyard or a campsite (150-300 lumens) or
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
____5-20 yards/meters (check out a noise in the backyard)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
____30-60 minutes (I have plenty of batteries just ready to be changed)
____90-120 minutes (Runtime is moderately important, but still not critical)
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
**12) Switch Type and location (choose all that apply):
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a tail mounted switch (found on the majority of today’s high end lights).
____No recessed tail mounted switch - fully exposed!
____A simple on-off with only one output level is fine for me.
____I want 2+ light levels. (Brighter/short runtime and Dimmer/long runtime.)
14)Material/Finish/Coating
____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today’s flashlights).
____Stainless steel (durable, but much heavier than aluminum)
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
None
Your criteria is pretty specific. I have a Klarus Rs11 but the switch is a body switch, but has integrated 18650 charging. Haven't seen integrated rechargable aa format with tail tail switch. Nitecore has something in their MT series that is tail switch and 18650 rechargable.
Almost any Surefire or Malkoff that will run on AAs sounds like the quality answer for you?
Really the same goes for 18650 and the Malkoff will be ready to run them out of the box.
An MD2 with H/L ring is a very nice light and they offer a TurnKey model for ease of spec.
There's a couple 2AA P60 hosts. That would give you the switch style you want, any emitter/reflector option you could even imagine and with you could carry a spare 18650 body with battery inside incase you wanted to switch on-the-fly to the 18650 power.
Maybe something to look into.
Ended up getting an Olight S35. Didn't have the tactical forward clicky, but it was close enough.
-td
