rookiedaddy
First, take a look at what packaging these cells arrived with... :sweat:
From what I understand, EagleTac got new cell types of RCR123, 14500, 17650 and 18650 besides a newer higher capacity 1700mAh CR123A primary. I only bought some CR123A and 18650.
First, let's take a quick look at this newer 18650 3100mAh Protected LiIon battery
a closed-up of the button top (nipple)
According to EagleTac, these 3100mAh uses Panasonic 3100mAh cell, and the label actually says "Cell made in Japan, assembled in China". EagleTac claim these can be discharge up to "4A - 5A", which is lower than the equivalent offering from AW or Redilast (both with Max Discharge Rate of up to 6.2A). Unlike AW (and sometimes Redilast) the "nipple" design should make these cells work in any 18650 flashlights.
Next, let's look at the CR123A...
loose plastic wrapping... instead of shrink-wrap.
1700mAh?
really? 1700mAh? :shrug:
compare the older 1500mAh with the this 1700mAh...
my previous experience and testing of the 1500mAh ET cell shows that the 1500mAh ET cell doesn't really deliver, the performance is lower than that of my 1400mAh Sanyo (made in Japan) CR123A. So I am a little skeptical about the claimed 1700mAh... however, after my initial testing, I've found this cell to deliver about the same capacity (or more) as other cells like Energizer/SureFire. Note that my test deals with low current draw using a flashlight running in low mode (Quark Mini AA warm white). Has anyone tested this newer 1700mAh cells in high current draw applications?
frankly, I'm quite surprise when I receive these cells. when the distributor told me it's "wrap" in recycle box, I thought it's one of those egg-shelf type of packaging... I never expect EagleTac to put each cell in its own individual box, nicely packed! Iimagine the labour involved in packaging these. :sweat: Though I doubt the practicality of packaging the cells like this, but I kinda like the boxes itself... it's cute! :whistle:
1700mAh?
