NEW Fenix ARE-X1 V2.0 Smart Battery Charger
fenix store
The Fenix ARE-X1 V2.0 is an upgraded battery charger with many great features to make sure you can quickly and safely charge your Fenix batteries. It includes a max charging current of 1500mA with a digitally controlled computer chip that will help extend your battery life. The ARE-X1 V2.0 also has a battery level indicator that will display both the charging and discharging status. This compact battery charger also has five levels of protection: over-charge, short circuit, over-current, over-voltage, reverse polarity. You can also use the USB Type-c port to charge or discharge. The ARE-X1 is compatible with many battery types, including the standard 18650 and 21700 size batteries.
Specifications
  • Compatible Battery Sizes: 18650, 21700, 26650
  • Input Voltage/Current: 5V/1.5A (Maximum)
  • Output Voltage/Current: 4.2V/1.5A
  • USB Output Voltage/Current: 5V/1A
  • Size: 4.2" x 1.3" x 1.27"
  • Weight: 1.6 Ounces
