New Olight Titanium, Stainless Steel XPG-S2 !!!
njet212
Indonesia
Just got email today about this new olight flashlight. I think this is the Christmas Edition.
OLIGHT M20 M20S+TC15+Mini AAA Titanium Cree S2 Set
M20S (Special Operation) XP-G S2 LED :
  • Utilizes a Cree XP-G Premium S2 LED with a life of 50,000 hours
  • Four modes of output, selected by click on off switch
  • 5 lumens (600hrs) 115 lumens (12hrs) 340 lumens (4hrs) Strobe 340 lumens with 10Hz (8hrs)
  • Linear functional adjustment for easy change of functions
  • Auto memorization of specific function for instant access
  • Tactical momentary-on forward switch, protrudent tailcap for easy momentary or click on
  • Side switch to select output when power on or direct access to strobe when power off
  • Superior heat sink disperse heat to protect LED electrical components
  • Textured reflector, perfectly centered light source, longest distance throw
  • Advanced low power warning, wrong battery direction protection
  • Mil-Std 810F Standard
  • Durable Type III hard anodized finish with textured anti-slip body
  • Lock-out function to prevent accidental on
  • Built-in steel pocket clip
  • Full metal cigar hold close to the momentary switch, anti-rolling, installed for strong hold, removable for smoother body hold
  • Water proof, anti-shattering ultra clear lense, anti-scratching and anti-slip
  • Strong Quick to release lanyard to prevent loss and easy access
  • Front removable steel striking bezel
  • Uses 2 x CR123A, 2x RCR123A, 2x 16340, 1x 18650, 1x 17670 battery
  • 14.0cm (L) x 3.35cm (D)
  • 120.5-gram weight (excluding batteries)
  • Compatible with Olight remote pressure switch
TC15 SS XP-G S2 LED (Stainless Steel):
  • Four modes of output, selected by forward clicky switch
  • 125 lumens (70mins) Strobe 125 lumens with 10Hz (140mins)
  • 52lumens (140mins)
  • Anti-shattering ultra clear lens, orange peel reflector
  • Water and dust resistant standard - IP68
  • Mil-spec MIL-STD 810F
  • Powered by 1x AAA 1.2v/1.5v/3.7v 14500 battery
Mini AAA Titanium XP-G S2 LED:
  • Three modes of output, selected by twist switch
  • 4 lumens (700mins) 30 lumens(105mins) 95lumens (50mins)
  • Powered by 1x AAA 1.2v/1.5v battery (10440 3.7v battery not recommandded)
OLIGHT TC15 TC10 Titanium Cree XP-G S2 Flashlight Set
The OLIGHT is a high-tech, rugged tool that's perfect for any lighting application. It features four levels of output, which not only allows the user to select the best compromise between brightness and runtime for any given task but also has ability to aid in an emergency. What's more, the OLIGHT throws an awesome beam, an incredible amount of light for a light of any size. If you're looking for a flashlight with solid reliability, digitally regulated brightness, and compact size, this OLIGHT is for you.
  • LED Type: Cree XLamp XP-G S2
  • Materials: Titanium Alloy
  • Finish: Polish
  • Reflector: Orange peel reflector
  • Lens: Anti-shattering ultra clear lens
  • Water and Dust Resistant to IP68
  • Switch: Forward Tail Switch
  • Mil-spec: MIL-STD-810F
  • Battery Type: 1 X AA Alkaline battery, Rechargeable Li-ion 1X 14500 1 X CR123A , RCR123A if with T10 Titanium battery tube
  • Size Weight (TC15): L 98.9mm x D 21.6mm , 66.5g
  • Size Weight (TC10): L 48.2 mm x D 21.6mm, 48g
Function: Two output levels and strobe
  • TC15: High 125 lumens (70 minutes) -Strobe 10hz (140 minutes)--Low 52 lumens (140 minutes)
  • TC10: High 235 lumens (110 minutes) -Strobe 10hz (220 minutes)--Low 55 lumens (420 minutes)
Operation:
  • Press the tail switch to turn on/off the light.
  • Gently press the tail switch when light on and release it within 1 second, light will enter into next mode. The cycle return is high, strobe then low.
  • Auto-memorize function: the light will enter into the mode you used last time automatically.
Note: when battery voltage is lower than 1.3v, there will be little difference for high and low output
I hate to see this light, sometimes i just could not resist to get it :shakehead
:popcorn::popcorn::popcorn::popcorn:
