New Photon Rex
PhotonLight
Eugene, Oregon
Looks like yesterday's thread was lost with the database restore (google still has it cached for the time being). Anyway, I just wanted to answer a couple of the questions that were brought up there about the newer vs. older Photon ReX.
There have been at least 2 major revisions for the ReX so far. Probably a number of other minor tweaks as well, knowing LRI, but as far as major, noticeable changes, I'll just stick with these two.
#1: The first was a tweak to the charging circuit. Early ReXes would sometimes manage to discharge their batteries below threshold where the charger would refuse to charge the battery. Basically the light would appear dead and not accept a charge. A simple work-around to resurrect a ReX from this state was to connect two AA (or similar) batteries in series and charge the battery for a bit with the higher voltage to get it over this "hump". Sort of a jump-start, if you will to get it back to normal operation. My memory is a bit vague, and I don't recall the exact date of this fix, but I believe it was sometime around mid/late 2009, give or take.
#2: The second, recent change was to upgrade the battery itself. After fix #1, some customers have still been reporting occasional issues with some lights like shorter-than-normal battery life, lights not holding their charge as long as they should, or just the occasional sudden failure, all of which apparently were eventually traced back to poor quality control on the part of the battery manufacturer. LRI ended up finding another battery manufacturer to custom build the battery to their specs. As far as changes between the new & old battery, actual battery life should be about the same, but the new battery provides a bit more power at full charge resulting in a slight boost in brightness. Additionally, performance is much more more consistent from one ReX to the next. This change was fairly recent, and the first ReXes to include the new battery began shipping on 6/28/10.
Both of these are definitely warranty issues, so if you have a ReX that is exhibiting any of the issues described above you may send it in to LRI for free replacement. Warranty instructions, return address, etc. may be found here.
Regarding the new USB chargers that were announced last week, yes the only way to get them for the time being is to get the entire package including both solar & USB chargers plus the clip. I checked with LRI, and (at least this time around) all of the chargers were manufactured as pairs, so they can't start splitting them up without ending up with a whole bunch of solar chargers with no USB charger to put with them. Of course it's possible this situation might change in the future, but for now you're stuck with the package deal.
I'm curious about the Rex Solar/USB charger (which I just received in the mail today).
There's a warning that you should disconnect the Rex from the Solar Charger, or the USB Charger once the Rex is fully charged or there's a risk of damaging the light.
Why is that? I have one of the very first Rex lights made, it still works like a champ (the switch sometimes needs a bit of extra coaxing, but that light has seen a lot of use). I've attached it to a battery to charge overnight many times, without any apparent consequences.
Isn't the Rex supposed to shut itself off to avoid overcharging? Why the warning with the Solar/USB charger???
Good question, mrmike. I also put my old Rex on its charger and forget it for a few hours. Some of the old ones suffered from higher voltage charging, like what USB would supply. Maybe this warning applies more to these old lights than the new "tweaked" model.
Geoff
My understanding is that the warning is just a precautionary thing. Once the battery is fully charged, the ReX is designed to dissipate any overcharge by turning itself on (this is the irregular flashing that is sometimes noticed after the ReX has already reached full charge) Apparently it is possible for a USB connection to put out slightly more power than the ReX can dissipate in this fashion. When I spoke with someone at LRI about this, they explained that they haven't actually been able to reproduce this, but it is theoretically possible that damage could occur if the ReX is left plugged in to the USB indefinitely, hence the warning.
Thanks, Bryan, for keeping us informed. I believe I'll be giving the new chargers a try.
Also, thanks for being very helpful in getting a problem fixed on a Photon 3 that I got from you guys almost eight years ago. I think I got it just prior to officially joining CPF.
Geoff
Thanks for the info! I picked up a ReX back when they first came out, I didn't realize that they'd been through so many interations!
Thanks Bryan
The Rex has been my EDC light since I got it. One of its' best features (which may seem odd) is when you're doing something that absolutely needs two free hands, it's easy to hold in your mouth, and doesn't taste like a car axle while you're doing so. :green:
Thanks Bryan
There's nothing odd in that; I do it all the time! I'm also a fan of its ability to start on low. That's perfect for a dark house in the morning.
I've had two rex photons for more than a year. One's on my car keys and the other's on my house keys. Both are working well and none have given any trouble to charge. Based you guys info I should be purchasing the charger soon.
