taylorID
Hey all,
So we all know about the issues with the Preon clicky tailcap... the button sits up way too high and it turns on in your pocket. Bummer. To resolve that, there are basically two options... (1) take out the metal cap and have difficulty reaching the on/off button due to the depth, or (2) get Zodiac Engineering to cut down your clicky's ring to make it easier to reach down into with your finger. I was leaning toward the ZE option... however, they're a bit backed up at the moment and both methods have the exposed rubber boot, rather than utilizing the metal tail cap.
So I took apart my clicky tail cap, brought it out to the garage and worked it over with a grinder (removing height from the metal cap off of the bottom section, as well as slightly cutting down the height of the plastic on/off switch) and a mill bit (cutting down the metal nipple/indentation inside the metal cap). Added an o-ring to the screw on top ring (for height/click activation purposes... plus it helps with waterproofing a tiny bit too).
I'm happy to say, it is perfect. The button is nearly flush (doesn't turn on in my pocket), utilizes has the metal cap (protecting the rubber boot), works flawlessly, feels like stock, it tail stands(!), and most importantly, it was free for me to do.
