NEW Rofis KR10 1100 Lumen LED Flashlight
rofisbenny
NEW ROFIS KR10 LED FLASHLIGHT
*Premium CREE XP-L HI V3 LED
*Maximum output of 1100 lumens.
*Max beam distance up to 257 meters.
*Max runtime up to 192 hours.
*Waterproof in accordance with IPX-8 (submersible to 2 meters).
*USB rechargeable. Intelligent memory function.
*Come with a Rofis 18650 Li-ion battery(3400mAh)
Lumens & Runtime
Turbo: 1100 lumens/1.7 hrs
High: 350 lumens/4.5 hrs
Medium: 160 lumens/11.5 hrs
Low: 65 lumens/31 hrs
Lower: 14 lumens/112 hrs
Moonlight: 5 lumens/192 hrs
SOS/Strobe/beacon
Length: 134.5mm (5.29")
Head Diameter: 25mm (0.98")
Tail Diameter: 24.2mm (0.95")
Weight: 75.5grams (2.66oz)(without battery)
Accessories
Rofis 18650 Li-ion battery(3400mAh), Holster, USB cable, Lanyard, Spare O-ring, Spare USB port cover, Clip
Any questions about this product, please feel free to contact us. Please send email to [email protected]
Lexel
Germany
Moonlight 5 lumens is too bright especially when it has a 14 lumens mode
is it forward clcky?
MikeB.
Iowa
I would agree that the 5 lumens should be much lower, preferably less than 1 lumen.
rofisbenny
About the moonlight, the result of the test is 5 lumens±20%, we will accept your proposal to reduce the lumens in later production. Thank you so much for your advice
Mr Baz
I tested the KR10 and found the lumen output in moonlight to be below the TR20 which is rated to 5 lumens by some margin it's maybe 2 lumens around that level. Not sure if I have an updated model but the lowest output is low enough IMO
