New Surefire prototype pics added
BigD64
I got a peek at an MCE version of the M6. All I can say is wow. 2 light levels with the high being about 500 Surefire lumens. Takes the 8 cell 123 battery pack and should put out 2 hours on high, low looked to be in the 30 lumen range (just a guess) and I have no idea on run times for low. I don't know if this will ever hit the market but if it does I want one.
Re: New Surefire prototype
Where did you see it at? Got any pics? If this is real, it sounds like a winner.
8 cell holder? Standard now is a 6-cell holder. Hopefully you just goofed here. It would be nice to continue using all the battery carriers we already have available to us
So in other words it's about as bright as the Seraph P7 head, but has a (desperately needed) low mode as well.
Hopefully they do something with CRI to make it interesting.
It is 6 batteries, my bad I looked to quick, no Pics yet maybe soon I have to get my hands on it again.
You're better off getting the Seraph head and a keychain light for low mode.
This LED M6 should be available by the time PK's great grand-children start designing lights for Surefire. :ironic:
:crackup:
:twothumbs
I did buy the LF seraph head, because i couldnt wait for an M3LT
Where did you get this sneak peak??
I'm thinking it is the LF head...
I know what a lumen is. Can you tell me what is a Surefire lumen and how it is different from a regular lumen (or is that proprietary info) ?
I know what a lumen is. Can you tell me what is a Surefire lumen?
Conservative measurement of output out the front. If Surefire lists a light as having 65 lumens, you know that you'll get, bare minimum, 65 lumens of light out the front. Usually you get a bit more since Surefire tests a large sampling of the same model, and then rates the average output across that wide sampling. This leads to rather conservative output numbers. Some companies also list lumens in terms of real lumens, as out the front. But they use a different standard than Surefire. Many companies still list over-inflated emitter lumens. (Output measured at the emitter itself, before the head is attached. Once the head is in place, output drops down by 1/3 or even as much as 1/2.) Since folks don't use flashlights without the head attached, measuring output at the emitter is retarded. But it's a nice way of pretending that a company's product is better and brighter than it actually is.
Now I am even more confused. You mention another type of lumen that I have not heard of, the real lumen. Let me rephrase the question:
1 Surefire lumens = ?? lumens
1 Real lumen = ?? lumens
Surefire lumens are real lumens. They don't measure output at the emitter.
OK, what then is the relationship between emitter lumens and real/Surefire lumens?
1 Surefire/real lumen = ?? emitter lumens.
SureFire set the standard for how to measure the lumen output of a flashlight.
Indeed SureFire is already implementing the industry standard it helped to develop. The "Flashlight Basic Performance Standard" (ANSI/NEMA FL 1-2009) introduces definitions and testing methods for flashlight basic performance as well as associated marking.
So in this regard there is no more recognised measure of a lumen from a flashlight than the one SureFire is using.
However, there is output variation from flashlight to flashlight as each individual LED in combination with the individual electronics used to drive it and the individual batteries used to power it, will generate variances that result in the output of each individual flashlight varying from the next.
Whilst SureFire doesn't uses terms like 'minimum' or 'at least' to qualify its lumen ratings, it is general acknowledged that SureFire isn't in the game of being optimistic with it's lumen ratings.
It seems that some other companies do not realise, or perhaps even decide not to take account of, the performance variation and determine to use a rating that only represents the better performing individuals.
The Flashlight Basic Performance Standard has only recently been published and many flashlight companies are either not aware of it, haven't finished undertaking testing to ensure their ratings 'comply' with it, or have decided to deliberately act to ignore it.
Al
Monocrom... you killed me! :crackup::crackup:
And we all know you´re right.
