Here is a new 3 volt lamp I just received that uses an LED that wasn't ground out by a third party, but was custom-molded by Nichia Japan specifically for this application.
This is a standard flange-style PR lamp with the inverter tucked inside the lamp base.
Marked "2.85V 0.1A"
The actual current measured for *this* sample was 120.1mA (0.12A) on a pair of nearly-new alkaline "D" cells (less than 5 minutes previous usage).
This is the new bulb installed in a cheap ($2) plastic Eveready D-cell light (the blue flashlight pictured below), compared to LEDCorp's "Our Best Aluminum Flashlight" with its focus just slightly loosened so the beam size is comparable.
The new bulb is the spot on the left; the LEDCorp is the one on the right.
The spot quality may improve when used in a light with a quality reflector - like a Mag or other medium to high end light.
Both of the test flashlights were set upright on a table and shone at the ceiling to obtain this photo.
The bulb is available from Abitax for $14.
I have a link to them on my
Abitax Tag Light page, which will do until I make a seperate page for this bulb.
Note: The bulb is meant to be used in 2-cell (C or D) Mag Lites. Since I don't have a 2-cell Mag, I cannot test it in one.
A test hookup using the lampholder & reflector from my Turtlelight produced the expected narrow Turtlelite-like beam.
