precisionworks
Not flashlight related per se but a workbench is the most essential piece of equipment in any shop IMO. Decided to build a bench area in the attached garage to keep gun repair visitors out of the main shop - too much stuff in there that might tempt someone to do something stupid.
Finally got the new furnace/AC installed in the garage:
Early in the installation:
Final install showing shelves removed on left side of unit:
The butcher block table is 24" x 24" and is a moveable bench. The area right of the butcher block & left of the furnace is the location for the new fixed workbench (green rendering).
After constructing a lot of benches over the years the one that works best for me is a top laminated from multiple sheets of MDF. A 48" x 96" x 3/4" sheet cuts down into four pieces 24" x 48", just the size needed for the bench top. Thickness on a four piece glue up is 3" & that's a bit thin so I glued up eight pieces:
There are never too many clamps in the shop:
Glue up finished & shown with 1/4" tempered Masonite work top surface. The Masonite is held down with four small wood screws & is easily replaced when it gets too chewed up. Solid oak edging will be attached to the front & sides of the top. Weight of top is 205# (93 kg). Since the table saw surface was scraped & trued dead flat it provided a good reference base to support the top during glue up. The Starrett 48" straight edge shows that the top is flat to within 1/64" in every plane - http://www.starrett.com/metrology/product-detail/Precision-Measuring-Tools/Precision-Hand-Tools/Precision-Rules,-Straight/Straight-Edges/385-48
More photos to follow.
