Here's my completed help me figure things out questionnaire.
1) How would you prefer to purchase the light? Prefer local if a good B&M store.
____I would like to purchase the light from a brick and mortar store. I am located in Houston.
____I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
____Less than $100.
3) Format:
____I want a flashlight.
4) Flashlight-specific format/size:
____Every day carry small (2-4 inches).
____Every day carry medium (4-7 inches).
____Holster carry.
5) Emitter/Light source:
____LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
____I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
7) What battery type do you want to use? Prefer standard AA available anywhere but only if all brightness options are available.
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible). I'd like to see numbers on property when I'm looking for a consignee at 0dark:30 so I need a very bright option for very limited use with preferably a few options for all other uses.
____I want to navigate a dark room or read a map (0-10 lumens).
____I want to walk around an unlit rural area (50-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
9)Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply. See note above to #8.
____Less than 1 yard/meter (reading, other close work)
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____5-20 yards/meters (check out a noise in the backyard)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
____30-60 minutes (I have plenty of batteries just ready to be changed)
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights. Will mainly stay in holster on my belt when not needed... maybe split the difference
12) Switch Type and location (choose all that apply):
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a tail mounted switch (found on the majority of today’s high end lights).
____I want multiple light levels. (Some lights have 5-16 light levels.)
14)Material/Finish/Coating
____I don’t care.
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
____Holster
____Less than $100.
3) Format:
____Holster carry.
6) Manufacturer:
____I don’t care.
____Holster
