Nicad Batteries?
The F sized cell seems to be the one that I have. but I guess the D cell with 8000 mAH will be my choice.
Getting another 3M battery pack is out of the question financially, rebuilding myself is the only way, much less expensive by a long shot.
Thanks for the help.
George
The question now is about recharging.
The current cells are 7000 mAH and get a 16 Hr recharge.
The new cells are 10,000 mAH, will the existing charger be up to the job if a little more time is available for charging?
George
I'm guessing that it's just a dummy style trickle charger.. so just leave it plugged in for about 20-24 hour to ensure a full charge and it should be fine...
Also keep in mind that the new cells are probably not 10,000mAH, I would venture to guess that they are overstated more than the SAFT brand cells for capacity, they might be a little better than the SAFT, but probably not by 30%.
Eric
Thanks, use is intermitent so extra charge time is not a problem.
This unit comes with a step down transformer which delivers AC to the battery pack, the rectifier etc is built into the battery pack.
George
