This is a bit off topic so I hope no one mines. This pertains to a twelve volt battery pack for a drill. The way i understand nicads is when they are full they are 1.4 volts a cell and dead 1.2 volts a cell.. So since a 12 volt pack has 9 cells when fully charged it should read 12.6 volts.. When dead it should read 10.8.. So If i put a meter on the pack it should be between 12.6 and 10.8, right?? So if it is close to 10.8 volts it is proably time for a recharge right?? Then i read that when a pack is fast charged the cells have 1.55 volts in them and then slowly drops.. So when it just gets done charging it should read under 13.95 Right?? And to confuse me even more, can some one explain the memory phenomenon? Where a pack loses it ability to hold a charge for very long? And is there any way to reverse it?? I read that some times freezeing a pack will reverse the memory? I am trying it now on a pack so I will let ya know.. What is your opinion?
Thanks in advance for teaching me the basics of nicads..
Later snapper..
Later snapper..
