sitdwnandhngon
- Joined
- Dec 18, 2019
- Messages
- 2
I used to lurk in this forum several years ago while dabbling in custom lights, so I figured this would be the best place to ask this question.
I was recently given some MAX tools (rebar tools) that use 9.6v NiMH battery packs, each pack is smoked, they either don't take a full charge or won't charge at all (age related for sure).
The smaller tools use 2.0 mah packs, the larger tool uses a 3.3 mah pack.
I have found some refurb units available, but before buying a whole pile of them I was wondering if it would be possible to just replace all the cells with NiCd cells, as they can be salvaged dirt cheap from Harbor Freight and Ryobi battery packs.
I have multiple chargers for each, and could try to find some specs for them, but I figured I would ask here first to see what you guys think. I've replaced cells on old NiCd packs before, but have never had a tool that uses NiMH cells (everything else I own and use for work now is Li-ion)
This is what the larger packs look like. Thanks
