Nitecore Extreme Weapon Mount
jdhaines
Hello all, I have been hanging around here for the last few weeks reading and learning. I have decided on the best light for me right now, and it is the Nitecore Extreme R2. I was just looking around, and I can't seem to find any information on weapon mounts. Is a weapon mount currently available for the Nitecore Extreme? Thanks ahead of time.
By the way, I searched and couldn't find the problem.
-Josh
Measure the diameter of the body. If it is 1-inch/30mm--then just find a 1 inch/30mm scope mount, and wrap the light in something protective like a rubber tube, and then mount it on.
Otherwise, I have no idea, sorry.
The NEX should have a diameter similar to that of a Surefire E-series light (.8"). If that is the case, several manufacturers make mounts for lights with that diameter body. Surefire's M78 mount is one example.
Not to thread jack, but would the recoil likely affect the light? With the piston design, would the recoil tend to turn the light off or change setting?
