Nitecore knock-off
southplinker
Saw this cool little light "super defender" for $20 and bought it only to learn later that it was a knock-off of nitecore extreme.
the emitter
and some outdoor shots with the Jet-I pro V3
"super defender" on high with AW RCR123
jetbeam on high with AW 14500
hey for $20 I like it a lot. UI is high-low-strobe via half-press but sometimes it starts with low or strobe but i don't care:D
Thanks everyone!
looks a lot like romisen's rc-a4 ll, which looks a lot like the nitecore. the romisen is available at shiningbeam for $23 and i would assume one would get better quality and customer service from them as well as faster shipping.
Nitecores OEM fabricator in asia has been doing a lot of work for others lately. One of my heatsink suppliers was giving these away at a recent mechanical engineering convention. Its higher quality than any of my other China-origin lights, and it definitely feels and performs like a type III finish.
Hi southplinker
Have a look at the sacredfire
[link removed - DM51]
Does it look the a same like pill, finish etc
where did you buy it from?
I got it from an airsoft shop in one of the malls here in the Philippines.
Wow that is a very solid light there! I curious to as how the UI works.
Boo. Don't like knock-offs. :thumbsdow
Sounds like this one is a knock-off only in external appearance.
Why waste the money on rip-offs that don't work properly ? Better to buy the real thing and only spend your money once - IMHO.
+1 Use it a dozen times,it breaks,goes in the trash bin.Waste of money.:sigh::sigh::sigh: :naughty::naughty::naughty:
kramer5150,
how's the UI?
Not bad for a mode flipper with strobe.
-LOTC, reverse clicky
-Last mode memorizes if left on for 1 second or more
-From Hi, half press for 1 second to switch to low.
-From Lo, half press to activate strobe
-From strobe half press again to activate Hi
Sounds clumsy but its not too bad. The strobe can be quickly flipped through with minimal disturbance going from Lo to Hi. Nice thing is it wont jump out of high unless half pressed for a second. I can signal-flash or do a "manual" strobe and remain fixed on Hi. Going from Hi straight to strobe though is a bit difficult.
