I received the LR70 from Nitecore for the review.
The LR70 is a hybrid flashlight lantern, with an integrated battery USB-C rechargeable that can also function as a powerbank (10'000mAh).
The LR70 comes in this box.
LR70, manual, USB-A USB-C cable, USB-C USB-C cable.
The LR70 is composed by a translucent plastic body, that holds the battery and 3 series of NW HiICRI LEDs, one on each side. There's also a red LED on each stripe of LEDs. The light measures 113mm x 60mm x 34mm, weighting in at 271g
The metallic head, that has the 2 buttons, the USB-C port and the 2 SST-40 LEDs. The 2 buttons are electronic, and are placed one on the short side of the head (to control the flashlight LEDs, like you would in any regular light), the other on the wider part of the head (to control the lantern LEDs). They are different in size, and shape. They protrude slightly from the body, so are easy to find with the hand in the dark.
The head has a foldable metallic D-ring to hang the flashlight
The 2 SST40 emitters, under tir optics
The USB-C port is protected with a rubber cover port. The USB-C port allows the LR70 to function as a powerbank, with a rather quick 18W charging capability (Output: 5V⎓3A / 9V⎓2A /12V⎓1.5A), and also a Low current mode (to charge devices with small battery capacity).
UI
Beamshots
Runtime
UI
Beamshots
Runtime
