Nitecore MT42 Coupon Price $69.98 at GearVita.com
gearvita
The Nitecore MT42 flashlight is a high intensity hunting flashlight that specially designed for night hunting and searching. It uses a CREE XHP35 HD LED to emit a wide range of light up to 1800 lumens for hunting and searching. Crystal Coating Technology combined with "Precision Digital Optics Technology" for extreme reflector performance with maximum beam intensity of 55400cd and beam distance up to 470 meters.
To cope with unexpected situations in hunting, the considerate and intuitive UI of MT42 is designed. A forward tail switch for momentary on and a metal mode switch for all brightness levels and special modes. When the light is on, press and hold the mode switch to instantly access Turbo mode (1800 lumens).In addition, regarding tactical use and patrol duty, Strobe mode can be pre-set and accessed instantly by pressing the forward tail switch.
It is compatible with 2×18650 Li-ion batteries (button top), which have higher energy intensity, better power storage and longer runtime compared to common AA batteries. Standard size enables the MT42 compatible with multiple tactical accessories. Overall, it is a great choice for hunters, law enforcement personnel. Click to learn more about the MT42.
Now you can get the Nitecore MT42 on GearVita with the price of $69.98 by using the $20 discount and free shipping coupon code "NTCMT4220" during July 4 to July 12.
Product Features:
High Intensity for Hunting & Search
Light up objects near and far with the Nitecore MT42 long throw multitask flashlight. Whether you're using it for hunting, search and rescue, land management, camping or exploring, the MT42 uses a CREE XHP35 HD to produce a focused beam with up to 514 yards of throw. With a max output of 1800 lumens and five total brightness settings, you'll have just the right amount of light for any task. Three special modes (Strobe, SOS and Beacon) add even more functionality for emergencies and location signaling.
Simple to Operate
No fumbling with awkward interfaces here. The MT42 features a tactical tail cap for on/off operation and a mode adjustment button located within easy reach on the light's bezel. With direct access to Turbo and the previously used setting memorized, you'll always have the output you want at your fingertips.
Extended Runtimes & Durability
Operating with 2x18650 batteries, the MT42 can run for up to 530 hours in ultralow and up to an hour on Turbo. A built-in power indicator light under the mode button reports the remaining charge so you'll always know how much power is left. This durable flashlight has an IPX8 waterproof rating to withstand sleet, snow and internal shock resistance to withstand recoil when mounted and blunt impact if dropped or used for secuity.
Far-Throwing Beam
The Nitecore MT42 LED search light features an incredibly bright and far-throwing beam that is perfect for use outdoors, such as while hunting or while on a search-and-rescue mission. The hand-held flashlight offers five output modes ranging from an 1800-lumen Turbo to a 1-lumen Moonlight mode. This means the same light you use while searching the forest can also be used to illuminate your tent at the end of a long day. The Nitecore MT42 is more than just a bright flashlight. This hand-held search light is equipped with a special Precision Digital Optics Technology to create an unbeatable 470-meter (1,542 feet) beam throw. That's 0.3 miles! The Nitecore MT42 LED flashlight also offers three specialty modes (Strobe, SOS, and Beacon) for silent communication and protection.
Power Indication Keeps You Informed
This LED search light was designed with longterm search-and-rescue missions in mind. The Nitecore MT42 is equipped with a patented power indicator light, located within the metal side switch, to notify a user of the batteries' power level. To activate the power indicator, first, make sure the light is turned off. Next, simply press and hold the side switch and then press the tail switch until you hear a click. The blue power indicator light will flash three times, when power levels are above 50%, twice when power is below 50%, and once when battery levels are below 10%. Now there is no excuse for a dead battery to catch you off-guard. The Nitecore MT42 LED search light runs on two 18650 button top batteries, which are sold separately. Please note that CR123A and RCR123A batteries are not compatible with the flashlight and could potentially damage the LED.
Dual Button Operation
The Nitecore MT42 uses a two-button design to simplify the operation process. To activate the constant-on functionality of the search light, simply press the tail switch until you hear a clicking sound. To cycle through the five different modes (Ultra-low, Low, Medium, High, Turbo), you will then tap the side switch located below the head of the light. This LED search light is also capable of producing a momentary-on output through a half press and then a hold of the forward tail switch. If you would like to instantly enter Turbo mode, simply press and hold the side switch. Finally, the Nitecore MT42 offers instant access to the specialty modes by quickly tapping the side switch twice for Strobe. Once in Strobe, press and hold the switch to cycle through the different specialty outputs. This LED searchlight, with its extremely bright and far-throwing beam, is an excellent addition to any law enforcement professional's or hunter's arsenal.
Detailed parameter informations please click: https://gearvita.com/nitecore-mt42-1800-lumen-high-intensity-flashlight-for-hunting-search.html
