Laser_Project
Is this a legit battery from NITECORE?
I took the wrapper off of one of my NITECORE NL2150HPR 21700 batteries and found this marking under it. Also, the engraved end of the battery is simply a thin piece of metal which can fall off after the wrapper is removed.
The reason I removed the wrapper is to fit three of them into a Fenix TK75 battery tube, they then slide smoothly inside the 45 mm ID tube with no wiggle room, when the wrappers were on they couldn't go in. Next, to design and fit with a battery cap to interface to the head and provide a negative return.
The photo showing the batteries sticking out of the tube is just for the photo, they are reverse of the way they would go in the tube later. The LED's will be removed from the head and laser diodes installed later.
There is another thin layer of plastic material below the main wrapper which appears to have been painted on which has a warning printed on it not to use the battery if the wrapper is removed. What is the reason? Perhaps for devices which must have the negative shell of several batteries completely isolated from one another, such as when in series with other batteries surrounded by a negatively grounded tube? Edit: Thinking more, I can see this is so and I won't be able to use these in series inside this flashlight tube due to that
Anyone have a flashlight to recommend for my laser diode modification which has a large heat sinked head on it which uses a 50 mm or larger ID battery tube to recommend? I have been unable to find a flashlight which uses three or four strings of two or more 21700 batteries in series to produce 8.4 or 12.6 VDC.
Due to the drivers I plan on using and the way I want to wire this project, I cannot go above 12.6 VDC.
