[ QUOTE ]
quickbeam: if i'm not mistaken your readings would indicate the intensity of the beams of the P60 and P61, not the total light output (lumens). the beam of the P61 is larger than that of the P60, hence that's where the extra output of the P61 would go.
[/ QUOTE ]
The 5200 and 7000 figure is from reflected light bouncing around in the Lightbox Apparatus and not a direct reading from the beam. Therefore it is reading a relative number that describes the total output of the light as near as I can tell. The width of the beam doesn't matter. There is no where else for the light to go, really. Lumens are measured in the same basic fashion - reflected light indirectly striking a sensor. Please look at
the construction of the Lightbox Apparatus. Intensity of the beam itself is read in LUX and is listed in red on the chart.
[ QUOTE ]
About the P61 readings that in our website.
P61 rating 120 lumen get 7000 overall output, however, compare M3 rating 125 lumen get 10000. My P61 seems get higher readings. My P61 & Surge(9000)give about the same overall output.
[/ QUOTE ]
You say your P61 gets higher readings - are you sure??? Are you taking readings with your own lightbox? If not, your eyes may be getting fooled. It's exceptionally hard to tell just by looking at the beam, which is one of the reasons I built the lightbox so we could get some actual numbers.
Don't compare my readings to Mfgr described Lumens. Mfgr Lumen ratings are coming into question a lot lately and I don't think there should be any exceptions made for any manufacturer. I'll stick with my numbers for comparison sake since they're all being done on the same identical apparatus.
FYI, I was never really impressed with the P61 compared to the P60, and my objectively obtained numbers seem to explain why. (although there are huge margins of error as a result of the only semi-scientific nature of the apparatus which are mentioned in my description of the device on my site)
__________
Al hit the nail on the head.
