koala
Hi all,
I just got my Q3 today. Rip it apart and I got SX1K Lux III. I am surprised with the designed of the Zetex circuit. Looks like the designer omitted the input cap, output cap and output diode. Look at it again, its' a Zetex circuit in an unusual configuration. The inductor henry is very small, probably less than 10uH. The sense resistor mark R020, so it's 0.020ohm ?
The red positive and blue negative are cell input. The LuxIII negative output(OUT -) is the lower junction between the 310 and transistor. The circuit board is double sided, nothing much on the other side. Output tracks are very thick suitable for transporting more electrons :naughty:
I proceed to test the efficiency of the circuit with my power supply the data is a below...
Current In at 2.9v : 700ma
Current Out(at Luxeon) 2.5v : 470ma
Current In at 2.6v : 650ma
Current Out : 390ma
Current In at 2.4v : 620ma
Current Out : 340ma
The voltage measurements are closed circuit voltage. A xxxK bin LuxIII is probably driven at around 1.5watts when using a 3v cell. I tried adding a 1000uF output cap, no workie the circuit refuse to regulate. I will try modding the sense resistor later. Is there a way to improve the efficiency of this circuit?
EDIT: MrAl teaches how to use a 0.1ohm resistor to determine the current flowing through a circuit by reading the voltage across the resistor. With this method I obtained different results.
Current In at 2.9v : 810ma
Current Out(at Luxeon) 2.5v : 610ma
Current In at 2.6v : 740ma
Current Out : 490ma
Current In at 2.4v : 690ma
Current Out : 420ma
I find measuring current with 0.1ohm resistor in series produce a very good consistency. I can duplicate the exact results if my power supply is setup properly. I also tried a 0.01ohm 1% resistor suprisingly the results are the same except I am limited to 1 dot digit when reading mV range.
I used a Dale 0.1ohm and 0.01ohm with 1% tolerance metalchip smd resistor for the test above.
Vince.
Current Out : 390ma
Current Out : 340ma
Current Out : 490ma
Current Out : 420ma
Vince.
