I am planning to modify my 4D maglite (the new version with D in front of the number) into a dive light, and would like to have an advice on which size o rings I should buy. What I have read so far (e.g. here: http://www.scubaboard.com/forums/do-yourself-diy/272038-o-rings-mag-light-conversion.html) it seems like I should go for:
1) Outside lens - NBR70 ID 48mm x 2mm
2) Inside lens - NBR70 ID 48mm x 2mm
3) where the head connect to the tube - ?
4) Tail cap - NBR70 124 or 1 3/16 ID X 3/32 c/s
I have a some doubt about the inside lens (number 2) since when I measure the original o ring it seems to be closer to 50-51mm than 48mm? Furthermore, what is the sizes I should look for for number 3 and 4 NBR70 124 doesn't say me much and 1 3/16 ID X 3/32 c/s according to this conversion table (http://www.broadleyjames.com/o-rings-size-chart.html) is 29.87mm and the original o ring seems to be around 33mm in inner diameter?
My guess (from what I have measured) would be to use:
1) NBR70 ID 48mm x 2mm
2) NBR70 ID 50mm x 2mm
3) NBR70 ID 37mm x 2mm (but this is more or less similar to the original)
4) NBR70 ID 33mm x 2mm
I should say I don't know if I can get these sizes, and it doesn't have to be metric this is just what I figured could work, but what do you say...:shrug:
Thanks, Magnus
Thanks, Magnus
