Sorry, long post time...
OK, so after collecting parts for what seems an age, I've just had my ECE OEM bixenon installed. They are AL 3" Bixenon.
Few pretty poor pics below:
I'd very much appreciate any help/answers to some/any of the points I have below.
My 4 questions relate to the aim and output of the projectors.
Initial aim was set (on purpose) too low and later moved up. Following manufacturer (and DS lighting guide) ie ECE 1% so @5m distance the lower right portion of the beam is 5cm below projector centre point and at 10m, 10cm below cp.
Adjustments made were on the conservative side and after a quick test run I must say I'm a pretty underwhelmed.
As this is my first experience of projectors I'm not yet used to their beam characteristics.
Output width-wise at least is vastly superior to my reflector setup.
In terms of throw the transistion from illuminated to non-illuminated areas seem very, very abrupt and very close to the car.
Perspective issues aside, it looks like only about a few car lengths of illumination before the cut-off begins, I would not be at ease using them out of street-lit areas at any speed as they are.
Q1: Are these just the traits of all projectors in general at play here or do I need to double/triple check the aim?
When I moved the aim slightly up to the point where illumination seemed a bit better I got flashed by a big truck, I don't know if this was just a coincidence as no more flashes from there on.
Note: The "did I get flashed or not" is not the method I'm going to use/employ to check aim, it's not the correct way to do things.
Q2: Throw-wise when correctly aimed what would be the ball-park figure of distance before cut-off for ECE projectors?
Q3: Poor pics but is the amount of colour artifacts around cut-off normal for such a unit? They are yellow at close range and shift to other colours at range. These projectors are stock in terms of the optical path and no mods to the shield or lens placement have (or will) been performed.
Chinese Burner:
Osram Burner:
Chinese burner had big issues and not in use, am using new Philips CM d2s.
Q4: Assuming I recheck the aim again and am satisfied with the throw, my other concern is the self levelling for my particular car model does not occur on a continuous basis. The control unit only polls/samples the 2 hall-effect level sensors approx every 30 secs or so.
This means that ridges and road imperfections that upset the car will not be reacted against fast enough. I have witnessed many other xenon projector shod cars that seem to have this nodding phenomenom too so is it really a non-issue as it isn't a constant mis-aim?
I've yet to get any night time shot of the xenon but did take some long exposure shots of my standard Philips H7 reflector setup.
Day Control Shot:
It seems to me that projector adjustment is a fine line from being sufficient to get any depth versus not causing excess glare.
If I cannot get at least a similar (hopefully better otherwise what's the point?) throw result from the projectors whilst still being safe for other users then they'll be coming out and the reflectors will go back in and lessons will be learnt!
TIA
********Update: Bixenon pics added.************
Had to reduce exposure time to 3 secs for the bixenon pics and change to daylight white balance. Thought my camera had gone bad, with tungsten WB set a pic of xenons came out almost green. Should have shot the halogens with daylight WB really.:oops:
The 2 shots below are same exposure. About 1½ hrs before sunrise for 1st pic, about 2hrs before sun up for second.
With bixenon active it is more than enough to see pretty far into the fields at either side.
Can't really say that I at least would need any more light than this, though still getting used to that abrupt projector cut-off.
Chinese Burner:
Osram Burner:
Day Control Shot:
TIA
