Old LEDs
Bolek
Paris
I still use old lights with P4 Cree led, sometimes eaven luxeon. There are not as bright as my new ones, but how is the efficiecy of old Cree ?
same current --> less bright --> efficiency worse
the XR-E still is said to be the easiest to focus
(that whole construction should be "promoted" with the new emitter plates)
I still use my Surefire E2L Outdoorsman. Single stage KL1 head with a Luxeon III. 60 lumens OTF.
I am looking to upgrade it to an XPG soon, though.
Jeff
I still use some SSC P4 based lights. From the perspective of beam quality, it's probably my favorite emitter ever, even if not the most efficient or brightest.
:thinking:I know that the efficiency is lower than e.g. XML but by which % ?
XR-E P4 @1000mA you get 180L
XM-L T6 @1000mA you get 400L
XM-L U2 @1000mA you get 426L
Forward voltage is 3.7 for the XR-E @ 1000mA
Forward voltage is 3V for the XM-L @ 1000mA
That means:
XR-E P4 - 3.7W - 180L
XM-L T6 - 3W - 400L
XM-L U2 - 3W - 426L
On Li-ion batteries it's easier for the XM-L to maintain regulation compared to XR-E, becasue of the lower vf.
Thanks.
So the XM-L T6 is 2.7 times more efficient that my old XR-E P4 @ about 3W. It's more than the ratio between efficiency of XR-E P4 compared to luxeon III
