Olight H16 Wave Headlamp - Turn On and Off with A Simple Wave of Hand
gearvita
The Olight H16 Wave headlamp represents the Olight's new generation of intelligent rechargeable LED headlamps that can use hand wave motion activation. With two parallel LEDs with a combined beam for both extensive flood and focused illumination, the H16 has a maximum output of 500 lumens with an adjustable beam angle. The built-in rechargeable high capacity LiPo battery supports a runtime up to 25 hours. The battery pack is located on the rear of the head strap for a comfortable weight balance with the LED system up front. The H16 Wave headlamp is a great choice for maintenance, night cycling, fishing, mountaineering and any other outdoor activity that requires light without taking away function.
Main Parameters:
LED: 2 x Cree XP-G3
Max Performance: 500 lumens
Peak Beam Distance: 100 meters
Peak Beam Intensity: 2500cd
Power Source: 1 × Built-in 2000mAh Lithium Polymer Battery Pack
Light Form: Far-range focused beam and close-range wide flood combined
Waterproof: IPX4
Outputs and Runtime:
Mode 1: 500 ~ 350 lumens ( 5 minutes ~ 2.00 hours )
Mode 2: 100 lumens ( 9.5 hours )
Mode 3: 5 lumens ( 160 hours )
Product Features:
● Hand Wave Activation
No need to fumble with buttons in the dark, the motion sensor activation allows users easily to power on the headlamp by waving in front of the unit.
● Bright Dual LED Headlamp
Using two Cree XP-G3 LEDs, the headlamp produces up to 500 lumen and 100 meters of throw.
● Wide Area Illumination
Dual LED light head paired with a custom lens delivering great close-range illumination combining both a wide and focused beam.
● Great Runtimes
Built-in a 2000mAh LiPo rechargeable battery pack that provides a runtime up to 25 hours of continuous use.
● Smart Power Level Indication
Four-level blue LED battery indicator and low-power audible beep warning at 10% charge to keep you updated on your power status.
● Beam Angle Adjustment
The light head has three adjustable levels from 0~45 degrees.
● Reflective Head Strap
reflective stripes on both sides of the head strap to improve visibility and safety for the user.
The Wave control lets the user turn the headlamp on and off with a simple wave of a hand! This hands-free activation prevents your light from getting dirty while you continue to focus on the task in front of you, it is really a practical function.
Come to GearVita to buy and experience it: https://gearvita.com/olight-h16-wave-headlamp-500-lumens.html
You may like:
cheap xiaomi 70 minutes smart wifi car dvr
cheap xiaomi mi 8 lite 64gb
