MartinDWhite
I and a friend mounted a OLight M30 on a FS2000 (nice .223 rifle). It is mounted in the foregrip with a machined out hole and two rings to hold it in the hole, so it is pretty solidly mounted. The two rings hold the light on each side of a polymer wall in the for grip and the round cut out in the polymer does all the other locating. It is a very solid mount. It will not move it shaken or if the gun is lifted by the light. We put the olight remote switch on it with the extended battery compartment and run it off of 2x18650. The switch works great.
After a few rounds are fired (more than 1 and less than 30) the light will change from high to low. We have not had it change back when we continued to fire. Is there anything we can do to keep the light on high? Why is is changing to low?
Here is the inside the front grip mounting.
