Olight T-10/T-20 ?
metlarules
Does anyone know if the Olight T-10 head can screw onto the T-20 battery tube? Inquiring minds need to know!
If it was possible and you did do that, wouldn't 2 cells burn out the T10 led/driver since it was designed for one cell use?
Am I the only one who thinks OLIGHT should take the T20 Tactical, put a 1 x CR123a tube on it, maybe modify the circuit abit so you'd get about 130 - 150 lumens on the 'high' setting, so you could have about 1 hour on 'high' and keep the other four settings and the same UI. Then you'd have a T10 Tactical, which I think would make a dandy EDC light.
