Phaethon
Hello everybody, i was thinking of building a bike light around cutter.com.au 's
MCPCB 6 up "Metal core printed circuit board for 6 x Cree XR/XRE leds. Board is aluminium, 70mm diameter by 2mm thick"
I will need to get someone to make me a 75mm alu housing on a mill/lathe, then hook up a maxflex with remote switch and a lupine handlebar mount (which will be positioned in the back and off-centre to bottom in order not to extrude a lot from handlebar height)
Moreover, i will blend 4 highest lumen cree R2's with two of warmer tint , for a smooth light output overall. The part is here:
http://www.cutter.com.au/proddetail.php?prod=cut839&cat=55
What do you think? Will it match the output of a $1200 lupine betty -not as slick though....-
Thanks for your thoughts....:candle:
