Having the switch on one end of the flashlight makes it more prone to damage. Recessing it helps somewhat, but it's still more exposed than a switch mounted midpoint on the flashlight. An end-mounted switch also tends to harder to access quickly.
However, end-mounted switches tend to make the flashlight a bit shorter, simply because most push-button switches are much thinner than they are wide. As an example, removing the center-mounted switch from a 2 D cell Maglight leaves you with enough room to install a third cell, if you install a push-button switch in the bottom cap.
