JimmyM
I had a 65W IRC running on 15 1/2D NiMH cells but blew the hotdriver. I had orderd a few 64458s to mess with (90W, 12V, 4000 hours). So i pulled the switch from my Mag138 and swapped out the burned HD.
I figured, what the heck. The worst that can happen is I instaflash a bulb.
So I dismantled the switch and cleaned and slightly modded an already modded switch. OK the moment of truth. Hit the switch and lit the '458. No pop! Wow is this sucker bright. My DMM showed 18 volts at startup which began to sag to 17.8, 17.7. I hadn't charged in a while. So I charged up the pack and ran it again. No flash. The DMM showed 19+ volts at start up then it sagged slowly to about 18V and held pretty steady. OK. Cool. So I figured, alright let's try a 16th cell. A fresh 16 cell pack lit the '458 and held pretty steady at 19.3 volts.
AWRs hotrater rerates the '458 to +175W at 19 volts. Now all I need to do is build a 16 cell pack (3x5+1) out of Elite1500s to fit a tri-bored 3D I have.
