osram mini dulux lumens output
davidefromitaly
43.66 N - 13.13 E
i have a osram mini dulux
with 2 ni-cd batts it absorb about 460mah, so the 3W lamp run at max 2,4x0,46=1,104W but we must consider a bit of inefficiency of the circuits
so the output how can be? 30 lumens? 50 lumens?
Not even close. From a tube like that, do not expect more than 20-25lm/W (my guestimation). And these low voltage input el cheapo converters are not too efficient...
I will measure it as soon as I have the possibility...
i have re-make a test with 2 fresh of charge ni-cd batts...
i turn on the light and wait 20minutes for full warm-up of the lamp...
i read the tension of the batts under charge 2,4v (i think 2,75 without charge) and the consumption of 920mah
so 2,4x0,92=2,208W
considering an efficiency of 20lm/w is 44 lumens...
Hey, does anybody know where to get these lights in the USA? Radio Shack doesn't seem to carry them any more...
yarddog sorry for my very bad english... /ubbthreads/images/graemlins/blush.gif /ubbthreads/images/graemlins/frown.gif
muppet you can buy one of them from some european seller on ebay...
No offence David... I just meant I didn't understand a thing (technical wise) that you said /ubbthreads/images/graemlins/smile.gif
no problem yardog, i'm not offence
i see also the osram dulux pocket, i think is the new version of the mini dulux, but i don't know the improvement of this lantern
someone know something more?
