Well, I can't take credit for the regulators, a friend of mine put those together. Very complex converters, using current and voltage tracking regulation. I need a 4" magnifier just to see the circuitry. There are like three inductors, multiple transistors, ICs, and and bunch of resistors and diodes on each circuit card the size of a dime. He made these at home; a true master of miniaturization. Looks like a small city with all the parts on each board.
I just hooked them up together, which wasn't really that easy either. Looked to be a simple mod, but physical dimensions control it all in the end. I used a piece of 1" PVC under the circuit cards for support. The wire hook ups all needed to be below the height of the inductors, so they could contact the heatsink. Took a lot of time, but with three nice regulators like these, I think it was well worth it.
Right now it's running the D cell test, still putting out 1700 Lux at one meter after 90 Minutes and pretty much starting to flat line the output now as the big D cells settle in for the long run.
