oveready C2 purchase help?
TheExpert
I want to buy a GID C2 with ZeroRez switch and a Torchlab H3 drop-in, my question is can I run either 18650 and 18350 without extensions in the same body?
The zerorez switch will work just fine with 1x18650 or 2x18350. It will NOT work with the zerorez shorty. That switch is designed with a recess so that you can use a specific cell setup.
ok, thats sweet then. while i have this thread here, any input as to what/if accessories would be a good idea to get?
what is the diff. between the pyrex and UCL lens? titanium bezel ring with the trits slots in my cart, got plenty of o'rings, Is the triad tail cap worth the extra money think it came out to $102? Also I run 1 x 18650 in the c2 but can it be protected or does it have to be IMR? I also don't know if I should go for the xpg or Nichia , how cool is the xpg over 6k? Thanks for all the help and patience guys this is gonna be one of my most expensive purchases and don't want to mess it up.
UCL allows more light through. So your "out the front" lumens rating would be higher. Both are durable, but pyrex is probably more durable. I have a mixture of both pyrex and UCL lens on my lights. The Triad tailcap would allow you to tailstand your light. Tint is a very personal matter. XPG would probably be brighter, but many on this forum love that Nichia Neutral HICRI tint.
hmmm, well I just added the frosted lens to my cart in addition to the clear ucl, I guess I just need some input on the led choice at hand.
Couple of thoughts...
UCL lenses offer 100+ extra lumens OTF, but are thinner and more fragile. Go with Pyrex for maximum durability. If you want to try both, just get extra lenses and request the bezel ring be loose installed.
ZeroRez are specialized parts with no length absorption. The main difference between cells will be the amount of force that is needed to activate with the the momentary boot. This pushes through the battery, against the stout spring of the Triple itself. You can expect something like:
IMR 18350 (short) - medium force
LiCo 18650 (medium) - heavy force
IMR 18350 (long) - max force
Output under LiCo will be the same. The regulated engine can 'pull' as much energy as it needs.
XPG engines are 6500K, with a mild blue and no green. Nichia are 4500K, with a smooth creamy white. Its about max output vs maximum color, but neither have a distracting tint. XPG2 engines will be 5700K.
ok, that really helps i think i have it sorted out now, just gotta make a led decision................
