P60 Replacement Heads
I_SawTheLight
I'm working on configuring a special purpose hunting light (green and red leds) and have gotten several different lights that I like. In particular, I'm good with the Solarforce L2T.
But I would like to increase throw a little bit. Can someone recommed a screw on replacement head and SMO reflector that will be deeper and longer allowing me to utilize the existing drop in minus the reflector.
If I may ask, what drop-in are you using? I hear there are some different reflectors of the same size as your P60 head that are better suited to throwers.
This thread may interest you:
http://www.candlepowerforums.com/vb/showthread.php?319511-**-Finally-a-true-P60-thrower
Also, you might try searching for "P60 turbo head." Fivemega used to make some Surefire C threaded turbo heads.
--Edit--
It seems Fivemega is still selling these turbo c-heads
http://www.candlepowerforums.com/vb/showthread.php?239882-Surefire-Deep-Turbo-C-Head
Nailbender put it together for me, using a green XRE led, and I asked him to build it for maximum throw. Throw is good, now I want to make it GREAT with a special reflector/head.
