p7 flash light conversion
thwang
hi all
been building this light for too long other projects get in the way lol just to recap i started with a p7 dx flash light kd super p7 driver and a cannon camcorder 7.4v 6000mah battery pack plus charger so far i have about £44.i started with this just to see what it run like
it run way to hot so im at this stage now
much more mass so hopefully it should run cooler.
thwang
nice work,
how does the driver board go driving the p7 ?
does it heat up much ?
Also can i ask how you posted the pictures all linked together in one post like that ?
(sorry for such a noob question)
-Dan
just no blank line between the links,
hit "quote" and You see
PS: did it get too hot while riding, or while testing without moving air?
hi chaps
it got quite hot stood still walking at night it kept a constant temp but once you stood still again the temp rose quite fast so hopefully it should run cooler.but saying that now photonfantastic is selling 28mm reflectors so i might turn a new body as the reflector is 35mm with a 45mm id body.
thwang
hi all
final got my p7 finished the body just needs a final polish on the after say it leave my p4 triple looking like a 1 watt lux
beam shots
high
medium
low
and my p4 triple @ 1 amp
a big thanks to all the help i,ve had with building my lights.
regards simon:):):)
