I have a portable bench light I am building. It uses larger lithium battery packs made for remote control planes. Depending on the final voltage requirement of the driver, I could run anywhere from a 3.7V 5000mAH to an 11.1V 3300mAH pack.
I would like to use (4) XR-E Q5-WC emitters in a parallel configuration. I would like to drive each LED at 1 to 1.2A.
I am looking for a driver that would be small and cheap to drive all four emitters.
Have any ideas? I guess it would need 4 to 4.8A total to parallel drive them.
If it would make more sense, I could use very small drivers inside each of the (4) light heads, which are limited to about 0.60" diameter inside; one driver for each emitter that is. Or I could use a single driver mounted to the assembly somewhere else.
Thanks for any help with this.
