Dang, I posted this just as the CPF outage/crash a couple hours ago started, so the post was lost. So I have to retype/rewrite it.
I got this AAA from a fellow CPF'er, not expecting much in the way of brightness, but figuring it's likely to end up as a mod host. Sure enough, it's a beautiful little light, with some bugs that I expect that they've worked out in the production releases. Physically it's exactly the same as an Arc AAA except it's brass and the knurling is slightly different (the little diagonal grooves are further apart). The knurling is smoother, which works well with the brass. I always wanted a brass light and I guess this is the best size. Even for such a small light as this, you really feel the extra weight.
Issues this light has:
1) It's much less bright than the Arc AAA. It's closer to the original CMG Infinity. I guess I'm ok with that, if there's a corresponding increase in runtime--I haven't measured the battery drain yet to find out. I've never been crazy about how Arc and others overdrive their leds, and I guess this led is run within the manufacturer's tolerances, which is good.
2) Despite the non-overdriving, it has the blue-est beam I've seen from a white led. Get some better led's, Peak /ubbthreads/images/graemlins/smile.gif.
3) The led sticks out 1mm or so past the front of the light, unlike in the Arc where it's recessed rather deeply. That makes it more vulnerable to scratching, and also means that you can't stand the light head-down on the table or shelf. I guess this means Peak's electronic circuit is bigger than Arc's and left less space inside the head. I hope they've fixed that by now.
4) There's no foam pad to prevent battery rattle. No biggie, I can add that.
I do really like the looks for this thing, and it probably has a Luxeon mod in store for it one of these days, maybe using Lambda's microconverter if I can still get one of those. I also like the Arc AAA-style semicircular lanyard tab better than I like Peak's newer removable weird-looking tab. Best of all are the standable tails like the Firefly II. This brass light also came with a brass split ring, which is a nice touch.
Anyway, it's a prototype, so the issues above have to be understood with that in mind. I give it an A for appearance and machining, and about a C+ for electronics, partly because of how the led sticks out.
