Pila education please.
JonSidneyB
Greenfield In
I understand volume wise. 2 Pila 150S Li-ion fits is close to 3 123's and is at 7.4. So if they fit the flashlight, they are completly interchangeable between 123's, what problems will I run into.
Pila 168S Li-ion is similar to in size to 2 123's but is only 3.7 volts vs 6 volts. If I want to have a light fully interchangebale between these two, I need to have a light with a regulator that can handle this range?
If I invest in Pila's in the future, I would only want to use them if I could fall back on 123's without changing anything on the flashlight once set up.
Ok, what are my options?:
What lights will hold 2 Pila 150S Li-ion sucessfully and still be able to switch back to 123's at will.
The bigger question, Pila 168S Li-ion replacing 2 123's. What is out there or could be built that would be able to use these interchangebly and practically since I this would be switching from 3.7 volts up to 6volts and back?
Except for my single and four cell 123 applications, I think I would like to change all of my 2 and 3 123 lights to be fully interchangeable where possible, though thim might involve getting rid of some lights, buying more lights, and buying more mods.
What areas am I completely wrong in my understanding???
What are my options to switching to pila's without losing interchangability?
Q: If I want to have a light fully interchangebale between these two, I need to have a light with a regulator that can handle this range?
A: Yes, the KL heads are good for that.
Q: What lights will hold 2 Pila 150S Li-ion sucessfully and still be able to switch back to 123's at will.
A: The 3-cell Surefires (there may be other manufacturers as well) should work with 2 Li-Ion's. I'm using this setup in a C3 with a HOLA and I'm getting great results. White bright blinding light.
Q: The bigger question, Pila 168S Li-ion replacing 2 123's. What is out there or could be built that would be able to use these interchangebly and practically since I this would be switching from 3.7 volts up to 6volts and back?
A: Again, for regulated LED's (KL1, KL3, KL5), they're interchangeable on 2x123 and 1 Pila, though KL3 *may* not work as well on a single Pila, depends on the Vf of the LED. As far as incandescent, you have to change out the bulb assembly, there's just no other way around that right now.
I have gone almost exclusively with the 3.7V lamps on the 2-cell surefires so I could use Li-Ions. My P60 spares are all collecting dust right now because of that. I hope Surefire jumps on the bandwagon and starts recognizing the great utility and economy of using rechargeables in their lights. Currently, the only light I have on CR123's is the Arc LS. I also hope Arc will embrace the use of Li-Ion's in their lights as well.
CM
I've been using the 168S in my G2z with a 3.7 volt lamp. It is every bit the equal to the P60 using DL123's. The 2 cell lights will require you to change the bulb if you wish to use the 123's.
Now that they have a new 12v lamp, the GL4 is capable of using either the rechargeble's or 4 DL 123's and the lumen output goes from 130 to 190. the run time is pretty impressive.
Almost all of my SFs has been switched to Pila batteries except my E1e, E2e, M6, 10X and 9AN.
The only 3x123 light that I couldn't be able to switch to Pila batteries is SL TL-3 LED. Due to design of TL-3 LED's anode contact, it simply won't work on Pila's bat.
Alan
hmmm, I would have to go to LED on all my 6 volt lights or not use the Pila. My 6volt 123 lights are traveling lights and I would need to be able to go back to batteries and would not want to change bulbs each time. This should work out, I find I almost never need much throw. so this should work nicely, I could keep my E1e stock for those times I need through and have only one light that cannot be interchanged. Or I could let all my 6 volt lights be regulated interchangeable and use one of my 9 volt lights as my light for good throw.
The Pila 168s works nicely with the L4. That's been my setup since I got the L4. LitFuse also swears by this combination. He's going to present some run time data on this combination. Right now when shopping for lights, the first question I ask myself is "how easy is it to use/mod Li-Ion's in this thing". My 123's are now collecting dust /ubbthreads/images/graemlins/grin.gif
CM
Does the Pila 80 lumen LA fit in a Surefire in place of a P60 or P61?
