The following quotes are from all over the forum...
BTT
Cool stuff. I have a Surefire 9P with Malkoff and am waiting for FiveMega 2x18500 and 2x18650 bodies.
Also ordering the Pila charger.
Where do you find Pila cells? What exactly are their advantages over AW protected cells, if any?
What are the advantages of Pila cells vs. AW protected cells?
I understand both are pretty good.
http://www.flashlightz.com/product.php?p=pila_600p&product=171825&category=1225
Where do you find Pila 600P cells?
Does it come with adapters to be able to charge 17500, 18500 (as well as 18650)?
Should I also get PILA cells as well? I am looking to charge AW cells as stated above.
I want to use it to charge both 17500, 18500 and also 18650.
Do I need an adapter for the former?
In the process of taking my usual trek around the forum, I felt like I was seeing doubles or having a lot of deja vu.
I used the built in google search and came up with this with a search for "Pila AW comparison"
http://www.candlepowerforums.com/vb/showthread.php?t=169200
See post number 9 in that thread, as well as "edited in" text by LuxLuthor in bold red in the 2 OPs.
I then did a search for "Pila IBC spacer" and the second link that popped up was this:
http://www.candlepowerforums.com/vb/showthread.php?t=188653
I'm using this situation to make a point. The point is that, the answers to MANY questions are a quick search away, but may require just a little bit of time dedicated to finding them.
Eric
