Please Rec me a light
AKF
This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
Up to $50. Possibly up to $100 if it is truly exceptional. Don't hesitate to recommend more expensive lights for consideration. I follow the buy-once cry-once philosophy so if it is more expensive but will basically never die and meets reqs, feel free to recommend.
3) Format:
I want a flashlight (hand held/self contained).
4) Size:
SMALL - Every day carry (4-7 inches). Smaller is better if meets reqs ofc.
5) Emitter/Light source:
LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
I don't care.
I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
I would like a light from a specialty manufacturer (Possibly limited run/Custom).
I am interested in assembling my own components. (for example a “host” or flashlight body from one manufacturer, and a “drop-in” emitter from another source).
I intend to use "Primary"/Disposable Lithium batteries based on the usual AAA/AA/C/D and CR123 sized cells common to most stores (often a cold weather or long storage choice).
I don't care
I want to illuminate my entire backyard or a campsite (150-300 lumens). Possibly more if within price point.
SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
30-50 yards/meters (I have a big backyard). Obviously more is better, but this would be required.
90-120 minutes (Runtime is moderately important, but still not critical)
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
Very Important (Camping, Backpacking, Car Glove-box). I am usually very hard on lights.
I don’t know.
Other, please specify: I don't know much about the lingo when it comes to switch types. I want something that I can press and it turns on. Preferably in the tail. Have seen some "hybrid" switch fenix lights that seemed interesting.
I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
I want multiple light levels. (Some lights have 5-16 light levels.)
14)Material/Finish/Coating
Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today’s higher end flashlights).
Stainless steel (durable, but much heavier than aluminum)
Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
15) Water resistance
IPX8 (Submersible to greater than 1 meter for 4 hours)
16) Storage conditions
Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
Pocket/belt clip
Fenix PD35 comes to mind. It can take 18650 rechargeable batteries.
For something just a little smaller, you can consider my EDC, which is one of the Quark 2xCR123 'tactical' series lights. I have one of these in my pocket at all times. The only drawback is that it can't take 18650. But's it a few mm's smaller than the PD35 and easier to EDC in pocket IMHO.
Good luck in your selection!
Welcome, AKF! :wave:
Fenix PD35 also came to my mind... There's quite a size difference between 18650 and AA (or even AAA) based lights, and this in turn determines how pocketable a light is. So it would help if you could narrow down what kind of light output/runtime you really 'need', vs. what you'd like, and what pockets you expect it to go into. For example tell us some typical uses, or the type of situation(s) where you are most likely to run into battery limitations.
Hey, thanks for the suggestions! After some further consideration I really don't need those odd kind of rechargeable batteries.
I will say that the quark series is tempting, because while runtime appeals to me, so does the ability to use readily available cheap batteries, where the quark Lego system allows best of both if you buy two bodies.
Any other great suggestions with the change in requirements?
Probably going to use it for primarily EDC. The quark is really looking attractive to me.
I have been trying to find specifics on its UI, but have not been successful. Anyone have a link to a description of the UI for the different types?
Try Goinggear.com... they usually have videos of each light and how they operate. Come back with specific questions.
In that case I'd go for an AA light (lots of good choices within your budget), or a CR123A based light if you don't mind the higher battery price. AAA is even more pocketable but much less energy in a battery. Read: not the output you want, or very short runtimes.
A 2x CR123A based light is more powerful, but even the smallest ones among those are big enough that you'll find you don't carry it everywhere. Which kinda defeats the purpose of having it, imho.
Either the manual (downloadable?) or a review should explain how the UI works.
If you prefer drop ins, you might want to try out solarforce with the 50bucks or less than 100bucks price range. Last i checked the website solarforceflashlight-sales(dot)com provides international shipping at just 2bucks.
Mcorp
