Pls enlighten me : TWAK, etc.
Thank, eric.
Would that mean that TWAK is a 1-/3-/5-Watt LS that is capable of at least 67.2Lu, emitting White color, and has a forward voltage of 3.51V-3.75V? and TVOJ is greenish White at fVolt of 3.27V-3.51V?
So which is whiter -- TWAK or TWOK?
TWOK is supposed to be the whitest white
TWAK should be drifting slightly to blue
TVOK should be drifting slightly to yellow
See the chart Hotbeam did a while ago
Klaus
Yes, Akula88, you are correct. The tint that I've seen in Lux IIIs are only apparent when run at very low power or when compared side by side with other lights. This is bacause the new bins have a limit on their tint that is much less than that of the old bin.
For example, look at the picture above. The dark pink band next to the number 3 is the old bin 3. It covers an area that's greener than X1 allows and pinker than WA allows.
Daniel
So if some Luxeon X's are capable of 250 lumens, why don't we see Luxeon lights that bright?
I hope not :x
I think the higher rated output is purely down to better efficiency of the LED die itself, there shouldnt be any difference in lifespan. Whatever the bin of the luxeon, the rated lifespan should be the same.
