Potting vs. Bi-pin
tomcat017
NY, USA
Hello all,
I was reading threads, trying to learn how to build a mag85, when I came across a few pros/cons of the potted bulb vs. the bi-pin. It occurred to me that I really don't know precisely what makes a bulb "potted." Before I actually ask (so no one rightfully smites me), yes--I did search. I read tons of pages on CPF, none of which actually say what a potted bulb is. I though I knew. But then I remembered my streamlight SL-20X lamp, which has both the ceramic holding the bulb into the reflector (which is what I though potting was), and two pins on the back of the lamp. So--I wanted to ask what determines whether a bulb is potted or bi-pin (or some other kind of connector). Thanks, and I really am sorry for such a simple question--but I'm learning :grin2: .
Bi-pin 2-pin, lamp with two legs :)
"Potted" lamp will fit in mag switch with no modification, it is like standart mag lamp casing, only the bulb is other.
ok...kick me if necessary, but I'm still confused. What makes the potted bulb "potted?" Is it ceramic-ed in? And does that make my SL-20X lamp a bi-pin or potted? (its got some ceramic compound holding the lamp into the reflector, and it has two pins). If I understand correctly, though, thats still a bi-pin.
All bulbs have two pins; the difference is only if it's "planted" or bare. Similarly, houseplants have roots too whether you buy them potted (potted plants) or bare (bare-root).
When we refer to potted bulbs here it's usually a bipin bulb that is planted into a PR-base metal can. And bipin usually means a bare bulb by itself which technically does not include anything else--if it does, it's referred to as a "light assembly" (LA). A common type of two-pin bulb with integral reflector is called an "MR" base bulb.
