Powerex 9V Probs
Albinoni
Banned
Perth, Western Australia
A while back in 2009 I bought 2 new NiMH PowerEx batts off Servaas here in Australia and also to say thankyou Jeff for your great service :thumbsup:
Anyhow one of my 9V NiMH PowerEx batts was low and I decided to recharge it, btw I also bought the Powerex charger for it as well from Servaas.
I decided to re-charge the flat or low volt battery and the thing is, it took for ages and ages to charge, over 6 hrs. I know as a fact it normally takes between 2 and 3 prob 4 at most but rarely. I had both batts in the charger (the charger takes up to 4 batts), one completed the cycles or charge in a mere 2hrs and the other one just kept charging i.e the LED just stayed red on the charger, by rights one charged it turns green.
Now at 16.20hrs I took the batt off (gave up finally) and decided to test it with my multimeter, funny how it showed 11.5 volts. So I am bit confused to whats happening here.
The batt showed up well on the meter, yet again the LED on the charger never turned to green
Hello Albinoni,
It sounds like the cells within your battery are out of balance and the charger missed termination.
Mark the battery and if it happens again you will have to run a standard charge of 0.1C for 16 hours to see if that will re-balance the cells.
Tom
