powering an sst-90
hi,
you need a boost converter when you will use this battery with the sst-90, cause the battery is an lifepo with 3.2 volts. the sst-90 need 3.5-4.0 volts to run at 9 amps.
markus
hi,
markus
true
and maybe will be really hard find some 9amp boost circuit for the sst-90.
I want too some 9 amp boost circuit for the sst-90 and no way to find
